Muddydogs
Oct 06, 2014Explorer
Terryallan wrote:
Well I guess you need to argue that to the tire company engineers. Cause I don't know. All I know is that is what they are rated for.
Also. If you run 65, or 70 on 2 lane roads in NC you will be more than likely ticketed, and your drivers license taken on the spot. Just about every 2 lane road in NC has a 55 MPH speed limit. Only the 4 lanes have a higher speed limit.
As to being a hazard at 55. Again. Big wall with lights, see it a long way off. Maybe it's just a Utah thing to not be able to see a vehicle in front of you.
BTW. Nitrogen psi in tire does grow to some extent. Not so much as air. But it does go up as the tire gets warmer. Which is why race tires start the race with low psi, so that it can grow when the tire gets hot.
And as mentioned. My truck will tow as fast as I want, I'm just too smart to do it.
Out West most 2 lanes are 60 to 70 MPH limits and the Interstates range from 65 to 80. Most drivers on 2 lane roads run at least 10 over and the chances of getting a ticket are slim.
Guess I don't understand your big white wall deal or you don't understand me. I'm not talking about seeing a trailer I'm talking about the idiots try to pass a slow moving trailer in all the wrong spots like corners and hills. Its the poor guy coming the other way that has to deal with the head on collision with these idiots. I'm sure we have all had to deal with this, going 55 makes it worse. Drive 55 through Salt Lake City during heavy traffic and all you will have is a sea of cars flowing around you with quite a few cutting in front of you showing there displeasure.
Smarts goes both ways, to smart to drive to fast but smart enough not to create a back long of traffic behind you? Smart enough to pull over and let traffic pass? Idaho has a law that states if you are delaying 3 vehicles you need to pull over and let them pass, most slow 2 lane roads have spots to move over, most drivers think the signs are intended for others and they don't mean them.
I would hope with today's faster road speeds, bigger trailers and meaner trucks that ST tires will be reworked to handle more speed. I am willing to bet that 90% of the trailer towers out there have no idea there tires are only rated for 65.
