JRoberts37015's avatar
Aug 30, 2019
Venting....Push or pull?
Picked up my travel trailer about 3 weeks ago from a guy that had the roof replace and he installed 12v new vents. Shouldn't those vents when turned on be sucking air out? I know hot air rises and gathers more toward the ceiling. When I turned it on to check them to see if they work it felt like they were pulling air in instead of sucking it out. I believe he has them wired backwards. Am I right?
  • Lynnmor wrote:
    I made my fans reversible so that I can pressurize the bathroom at critical times. :E
    Pressurized explosive vapor? Isn't that what makes engines run? :@
  • Lynnmor wrote:
    Hold the toilet open and you will know for sure.
    That's funny
  • During the day both my fans pull air out but at night we perfer the fan over the bed bring in a gentle cool breeze. Its whatever floats your boat...no right or wrong.
  • Hold the toilet open and you will know for sure.
  • If you had the windows closed it could feel like air is blowing in. Open a window and you'll feel it fully.
  • Ok. Never mind. I checked them again and he has them in right. Its sucking air out. So Moderator if you can delete this I'd appreciate it.
