jdtrotter wrote:
It is a 12 volt compressor that is made by Dometic --- or they told us that Dometic recently bought out the company that makes them.
I can not read the model plate, but from the book it appears to be one of the CR models --- 50 or 65 and it does have a fan.  We bought this as an extra and if it works correctly, it should be a good refrig.  This is the second one they put in for us ---
The camper is brand new and we are still working out the bugs with the manufacturer.  This will be our first long trip and on our way home, we will be stopping at the manufacturer to address another problem.  So I guess we will have them check it out.
WE just wanted to know if the loud fan noise was normal because we don't want it to go out on our trip!  It is not loud at all inside the camper, just outside.
Thanks
On edit, it is plugged into 110 right now, so we will see.  WE do have a fantastic fan and it seems to run just fine with not strange noises.
You sorta lost me . In your first post you said it was so loud you could hear it inside your sticks and bricks home. In this post you say it is not loud at all inside the camper. Could you clarify so we can help. I have the same compressor fridge and can help you if you will provide the relevant info such as camper mfg,why your first fridge was replaced etc.
