billtex wrote:
I would check the area with a moisture meter first (ND) if that doesn't show anything...I think I would document with pics sent registered letter to OEM and forget about.
The one piece fiberglass cap SHOULD be very robust. If there is no sign of moisture, I would just consider it cosmetic and move on.
Can you say for sure if this bulge has been there all along or not?
1"-1.5" of "play" or sag?
Is it flexible...or just a bulge?
Bill
Hi Bill,
This is a sag, very flexible. I can reach under and push this area up that distance. I don't believe you can read moisture that might be behind the fiberglass through the fiberglass without making a hole in it.
I can't say for sure how long this has been there as it is not something you can easily see with the naked eye, only upon washing and drying diid I notice the problem.
