Gator398 wrote:
About these spring hangers ripping off.. this sounds like a serious quality issue since these trailers only weight less than 10k. I have only seen spring hangars separate at the weld on tandem single tire 102" wide goosenecks loaded over 25k we used in oil patch on awful lease roads, and even then the mechanic just welded them back down. Now I'm thinking the first thing I will look for if buying one of these TT is how flimsy the axles are holding on.. is this really that common?
More common than you think, more common that manufacturers believe. tahts because MOST happen after warranty, so the manufacturer has no idea since reimbursement was not made.
NOW, with that said, the sky is NOT FALLING.... Just keep a good eye
