Camper_Jeff___K
Jun 19, 2018Navigator
VIDEO: Installing an AC Coolingstat for temperature control
When in use, my Truck Camper AC unit is either on or off. It has no temperature regulation that shuts the AC off when the desired temperature is achieved. I installed a line voltage, single pole coolingstat, KING K101C, $40.00~, wall mount type, to the AC ceiling junction box, to see how it would work. It does work but I think the regulation of temperature would be better if the coolingstat were mounted to an internal side wall not directly heated by outside sources like the ceiling. I plan to relocate the coolingstat down near the breaker box shown in the video which I think will be a good non-interfering with other things location hopefully taking advantage that cold air is heavier than hot air and will drop down to the proposed coolingstat location. My AC unit seems to be able to lower the internal temperature down about 20 degrees F from what the outside temperature is so a limitation is that in practical use, I will have to not set the unit for more than 20 degrees F below the outside temperature or it may simply continue to run as it does now. I hope it will be better on those plugged in nights in hot areas so we can set it and forget it.
For normal fan or heat strip operation, turn the coolingstat set temperature all the way down and it will be in a run all the time condition down to 40 degrees F. The AC unit is generally only operated in summer so it shouldn't really be an issue since for heating I use either an electric baseboard of the main furnace.
J&K
J&K
