JimK-NY
Aug 08, 2021Explorer II
Obviously if the existing springs had been overloaded and were damaged and sagging, then a new spring pack would have been the only solution.
When starting with springs in new or decent condition, I recommend adding SuperSprings. The installation is really simple and the wheels do not even need to be removed. In addition the preload can be adjusted so the truck rides well unloaded. I would also get rid of the airbags. Mine rotted within a few years but they also added a lot of sway even at fairly low pressure. If something more than SuperSprings is needed, I would replace the airbags with Timbrens. They are maintenance free, last the life of the truck and the unloaded ride is unchanged.
