clev's avatar
clev
Voltage, amps, and watts
I'm a little confused on inverter use. I know that dealing with AC current, watts = volts x amps and using that formula, when I'm plugged into power, my 1200 watt coffee pot uses 10 amps of my 30 amp system. If I also use my 1500 watt toaster oven, my microwave, and my AC, I'll exceed that 30 amp limit and pop a breaker. My confusion is with batteries. I have 2 6-volt golf cart batteries, rated at 237 amps, hooked into a 2000 watt inverter. The 237 is DC amps, not AC. Does that equate to 23.7 AC amps? If I'm using my tv, satellite, and surround system all rated at about 10 amps, how long will the batteries last? 2.37 hours?
