clev wrote:
I use the inverter just for the tv, TiVo, and dvd. Occasionally, if I'm streaming a movie through my iPhone, I will use my surround system with subwoofer. And there should be no confusion on my initial post. If you read it carefully, I was simply asking how to compute usage time, regardless of what appliance is being used. Others started bringing in different appliances, battery size and number of batteries, and again I tried to steer replies to usage time; as I am doing now.
rjxj wrote:
LOL
That's constructive. :S
To the OP ...
You
yourself introduced the topic of inverters in the first sentence of your very first post -
"I'm a little confused on inverter use" so naturally that's going to be the reference point in any following commentary by others. :R Now you're complaining that those of us who took the time to reply to your query aren't being specific enough. :S OK, so to me the answer is obvious but if we have to spell it out ...............
Measure each device you're interested in powering with an inverter using a meter such as a
Kill-a-Watt Energy Meter to establish it's average power requirements in watts or amps and multiply each result by the time it's being used so you'll know the watt-hour or amp-hour requirement for each device. You already know your pair of 6 volt batteries offer about 230 AH, half of which is usable if you want to draw them down no more than 50% DOD ... at a nominal 12 volts that 115 AH is equivalent to about 1400 watt-hours.
How you use that reserve is up to you but rather than try to pre-calculate this out I'd find it much simpler to just do a test run, powering what you want for however long you want until your battery bank is drawn down to 50% DOD, keeping in mind that in a normal situation those batteries are not just powering an inverter and it's associated loads but also the rest of the trailer itself. If the results of such a test meet your requirements then you know your setup is sufficient for your intended use, if not you then know you either need more battery reserve OR you need to cut back on usage OR both.
If this isn't the answer you were looking for, my apologies - but at least it's more constructive than "LOL". :W
