APT
Apr 24, 2014Explorer
All three engines will likely get the same FE as your 1999 5.3L when towing. The 6.2L/6-spd combo will be a rocket compared to what you currently have though. unloaded fuel economy shoudl be similar to your current truck too. We get about 2MPG better under all conditions in our 2011 3/4 ton Suburban than our prior 2003 F-150, with far more power. If this will be a dedicated TV, I highly recommend a 3/4 ton. But for your weight limit, the 6.2L should be fine. I personally do not like the AWD system mated to the Yukon Denali.
44,068 PostsLatest Activity: Jun 10, 2026
