I'm having the hardest time finding wall studs. Normal stud finders don't seem to work. Is there an industry standard measurement like the 16" on center for a house? Thanks for any wisdom you can pass...
Some trailers use sandwiched pressure glued system for the walls. Plywood interior and plywood exterior with some sort of insulating sheet material all vacuum glued together. There are ribs in the walls but they may be placed where support is needed and would be random.
Most RVs you should be able to find studs using a stud finder. So i'm guessing you may have some form of this sandwich walls
