JimK-NY
May 31, 2018Explorer II
Most of the wiring in my TC is behind panels in the ceiling or walls. There is no way to pull any additional wires and I was not about to try to removing paneling. To install a socket on one wall I had to pull wiring under the kitchen cabinets, across the top of the water tank, under the edge of my dinette seat, and up through another cabinet. Remember with 12 volt wiring you will have 10 times the losses due to resistance when compared with 120 volt wiring. You need to think about 10 gauge or heavier wires. Because of the run length, I went with 6 gauge.
44,056 PostsLatest Activity: Jan 12, 2020
