beachbum2011
Jun 02, 2018Explorer
I added 12 volt circuits to my NorthernLite 8-11 QueenClassic
i Wasn't able to get wires to bed area , but i installed Blue Sea Systems 12 Volt Dash Socket and
Blue Sea Systems Dual USB Charger Socket in front of cabinet face
to left of sink. Next to hot water tank switch.
If you remove dinette plywood seat top from from over electrical panel. you will gain access to back of fuse panel . There are many unused 12 circuit wires coiled up back there.
find out which wire and empty fuse plug go together. Splice onto wire for positive connection.
For ground wire Cut existing ground wire and spliced in Blue Sea Systems Common 100A 5-Gang Mini BusBar to connect new ground connections.
The wires can be snaked under silverware draw and up face of cabinet to left of sink.
I Used #10 wire to minimize current loss.
Insert fuse and your powered up.
44,056 PostsLatest Activity: Jan 12, 2020
