My Coach man Catalina has been stationary this past year and plan on using it at my maintenance shop.my problem is my waste tank was full and had not been emptied for a while so i called my local sept...
The addition of a water softener into the tank will break the surface tension more readily than pure water. I use the cheapest laundry softener I can find. Others use Calgon or similar.
