No unfortunately i cant move it right now.the other bad thing is im in the process of replacing the hot water heater so im relying on the outside hose hookup for water pressure.which the pressure is great.i took a look this morning and the water in the toilet has already turned dark where as when i filled tank it was pretty clear.thats why i posted earlier about prodding around in there thru toilet although access is limited but i didn't know how fragile those tanks are.but i did put 64 ounces t s t brand in there then filled i just am not familiar with how penetrating that stuff works.
