plusplus
Oct 22, 2013Explorer
Water damage how to !
Hi all,
Just hope I'm in the good forum. I own a 2007 Jayco 186 put in service in May 2008, the particles board is like a sponge, I have to remove the existing floor and replace it with new plywood base floor (waterproof) and flooring (wife selection). I never done that work before and would need your knowhow so I would do a nice job and keep my TT longer (2 years) and have a solid and watertight TT. I have to remove all the modules that are sitting on the floor, strip the old flooring remove the Chipboard soaked with water. I have look on the WWW to see for the construction details for a Jayco TT but could not find what I was looking for.
The cost if I give it to a camper repair shop is 2 to 4 Thousand $, I can save that in doing it my self.
One repair man told me that they all have water infiltration and even a new TT is not water tight. What I will do since I learned the hard way is to remove all to trims from the top down to the base and inspect and reseal every year. I will also use some bounding tape to make the TT leak free (If possible!)
What would you do to make a good repair? Material, tip & tricks, Sealing tape, caulking type etc...
It may not be a very good English but at least I tried.
