daystrom
Sep 04, 2016Explorer
Mine did this. The problem is either the seal around the door has failed or water is getting into the latch and running down the inside of the frame.
That trim, at least on mine, appears to literally be vinyl covered cardboard. It will soak up the smallest amount of moisture.
I ended up resealing my door all the way around and replaced the trim with something similar I found at Lowes.
