kellem
Mar 23, 2020Explorer
RV plumbing leaks are common, easily fixable and usually show up before much damage is done.
Pressurize the system, run the shower and find the leak.
I'd also check all fittings and hand tighten, only takes a few minutes.
In the future, listen to your water pump.
If it cycles without water demand, there's likely a leak somewhere.
And yes, when the grey tank reaches capacity, it shows up in the shower 1st.
