TPUC wrote:
I can't tell when the tank is full until water is coming out the vent. I also don't like that fact that you can only fill from a pressure source.
Just because water comes out the vent doesn't always mean the tank is full. Every RV I've owned (4 now) act the same in that they burp and spit like an infant after a bottle. The best thing I've found is to just put the water in at a moderate pace as opposed to full throttle on the hose. Also, if you have the patience, holding the hose a couple inches outside of the opening can help in that it allows more air to escape as the water goes in. From my experience and others I've talked to, filling the fresh water storage tanks is just kind of a pain and you will often get some spillage.
