TPUC
Apr 17, 2015Explorer
Water Fill
Anyone have one of these? http://www.andersonbrass.com/rv_4_function_fill_station.php Do you like it? I find it a pain to fill the water tank. What am I missing?
4x4van wrote:whiteeye42 wrote:
using the pump even if your sucking it from a bucket or jug it still being under pressure to get it to the tank mine is the same way i wish it had the gravity fill spout would make it a whole lot easier to refill the tank from a jug when boondocking 20 miles off the beaten path as it is now i have made up a second pump that i use to refill my tank with
Does the hose fitting inlet actually "require" pressure to get through a valve or something? If not, make a sort section of hose; male fitting on one end to attach to the fill station, the other end with either a funnel or a fitting to fit your jug. Walah, Gravity feed!
