rgoldingExplorerOct 05, 2013Water Heater Anoid Rod IsolationInstalled a new heater rod into a Suburban Model SW10DE. Had to use an impact wrench to get drain plug and heater rod out. This is on a 2005 Artic Fox 30U, that may have sat unused for 4 or 5 years....Show More
ScottGNomadOct 05, 2013No the teflon tape will not insulate the threads. You can take an ohm meter to it and still get zero ohms to ground.Scott
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Tankless water heater
