rgolding's avatar
rgolding
Water Heater Anoid Rod Isolation
Installed a new heater rod into a Suburban Model SW10DE. Had to use an impact wrench to get drain plug and heater rod out. This is on a 2005 Artic Fox 30U, that may have sat unused for 4 or 5 years. Yes, it may have been that long since the drain plug and heater rod had been out. All's good and back together. No anoide rod, right now, but that should arrive this Monday or Tuesday. When I put anything like this together, I always use Teflon tape on the threads. It keeps things from leaking and seizing to the point of where you have to use an impact wrench. So will the Teflon tape prevent an anoide rod from working correctly? When we install sacrificial zinc anoides on boat prop shafts, it is important to make sure there is a tight ground attachment. In fact, there is even a bulge in the casting or molded in metal attachment to make sure it has a strong bonding. So wondering if the Teflon tape will prevent the zinc rod from working correctly?
    No. It's anode rod, and there will be some bare metal there even using tape.
