scotty46ExplorerAug 29, 2017Water heater not workingElectric part of water heater not working. Breaker has not tripped. Monitor light is lit, but no hot water. Gas heater function on water heater works fins. Any suggestions what to look for?
BB_TXNomadAug 29, 2017Bad elementBad thermostat/hi temp cutoutBad switch on water heater (Suburban)Loose wire/bad wire connectionVolt/ohm meter to isolate the problem (if you are comfortable troubleshooting 120 vac)
Related ContentOn-demand water heaters – do they work?water heatersWater HeaterWater heater issueWater heater plug
