TxTiger's avatar
TxTiger
Water Heater Sediment Question
I winterized my TH this week and was pretty surprised at the amount of sediment in the water heater. The drain is slightly above the bottom of the heater so the sediment tends to stay in the bottom after draining. Does anyone have any suggestions on how to get most of the sediment out? Should I just keep rinsing it and hope most of it works its way out, or is there something I could put in it to help break it down?
Thanks for any suggestions.
  • I too use a flushing tool like the one pictured by downtheroad. I have also used a wire coathanger that I straightened out and then bent a little hook on the end. Insaert it through the drain hole and rake out the sediment. Probably using both of these techniques will do the best job.
