WA7NDD - James - On my Suburban hot water heater I pull out the anode rod and let it drain. I was thinking this is the only available hole to use the HOTT ROD Electric Element kit...
Maybe I need to look my Suburban unit over again for additional available ports to use. Every season end I pull the anode rod out to inspect it and drain the Suburban Water heater for the winter months... This is my best spot to drain being on the bottom of the heater.
Guess there is always a catch to everything you may want to do.. Thanks for the info...
Roy Ken
