stevemorris's avatar
stevemorris
Water Heater Upgrade
our 15 yr old tt has a propane only WH and we would like to have electric heating too
is it worthwhile to add the stuff needed to a 15 yr old tank or should I just get a new tank?
the tank is in good working order but the burner gets blown out when its windy!!
  • You can buy what is called a hot rod. Basically a heating element that replaces the drain plug you then simply plug it into 120vac and your done. I do not believe they are too expensive.
