cavieExplorerJun 19, 2019water heatersWhy is it the all RV'ers have trouble with the HOT WATER HEATERS but nobody ever has trouble with a COLD WATER HEATERS??? Enquiring minds want to know!
Old-BiscuitExplorer IIIJun 19, 2019Technically it IS a HOT WATER HEATERAfter the initial heat cycle the t-stat closes at 110*F which by definition is HOT Water'Cold Water Heater' on initial heat cycle then 'Hot Water Heater' when reheating :B
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
