Huntindog
Feb 23, 2018Explorer
Passin Thru wrote:OP stated that everything was working fine until it wasn't. So unless he has been fooling with the valves, that won't be the problem
Look at all the lines and see if there are valves in them. My Arctic Fox has a total of 9, 3 for each sink, 2 sink drain valves and 1 fresh water drain valve between the axles where you have to crawl under to turn.
44,068 PostsLatest Activity: Jun 21, 2026
