kodiakcanuck
May 16, 2014Explorer
Water hook up horror story...could have been worse
Just a reminder to those when de-winterizing...Hooked up the house water hose to the city water connect last night to flush the lines. Turned on the tap then realized the trailer was locked, so I went inside to get the keys. My son was cutting the grass so I couldn't hear any noise from inside the trailer.
I was gone in total maybe 2-3 mins, came back opened the trailer door to water pouring out of the bathroom along the inside wall of the trailer back towards the couch.
The taps where left on full blast from when I winterized in the fall to relieve pressure. Somehow the plug go put in the bathroom sink and it was overflowing. :E
Grabbed a bunch of towels from in the trailer and soaked up the water, then got out the shop vac and sucked up as much water as I could from under the bathroom wall. I then ran some big box fans to help dry it up.
Hopefully there will be little damage under the walls and to the floor. The water wasn't sitting on them for very long, as I said maybe 2 or 3 minutes. I can only imagine how bad this would have been if I was gone longer :o
Word to the wise, always check the taps before you turn on the water :S You'd think I would know better, i've been doing this for 8 years...
