joeshmoe
May 22, 2018Explorer III
Hey, Nolan
Just changed my anode 2 days ago also, but didn't flush the tank. I try to keep from flooding the pan area as I have the same problem, though not near as bad as yours. The lip of the pan is bent slightly so sealant didn't quite span the gap I think. Been that way from new. Found out when I went to flush the tank the first time. Haven't flushed it since for that reason.
The other possibility is a cracked bung. But as someone said, even the slightest fracture would show up. But you know how plumbing works. lol
The way these water heaters are installed...I'm not impressed.
Maybe scrape that sealant and lay down a nice, thick bead.
LoL Not in So Cal.
EDIT:
Whenever I do anything with water on that side, I've made it a habit to go in and check with a flashlight. Ever since the flooding debacle with the tank filler leaking several mini-lakes under the sink cabinet, I don't take any chances.
anutami wrote:jimh425 wrote:
Did you winterize correctly?
what's that? I live in san diego county and my camper is stored in and insulated garage.
LoL Not in So Cal.
EDIT:
44,068 PostsLatest Activity: Jun 21, 2026
