bcbigfoot
Jun 22, 2016Explorer
Z-Peller wrote:
I had similar issue with 2002 2500 9.6 Bigfoot some years ago. Found that rain water was getting in at the back of the fridge at the bottom of the outside fridge vent cover sometimes if camper was leaning slightly to the left. My fix was to use an aluminum strip sealed with Dycor across the bottom of the opening about 1.5" high to make a lip so water couldn't run in across the flat area behind the fridge. When I got my new 2009 Bigfoot with Dometic fridge I checked that vent but found that Dometic had already put almost identical lip there from the factory. Hope this is your problem too as its an easy fix.
This was my issue as well on my 2005 9.6 2500, and came up with a similar solution.
