seaweed2ExplorerNov 14, 2016water pressureI have a 2016, 24ft Open Range Lite. The water pressure is the barely a steady stream. At home I hooked up without regulator and made no difference from using a 45psi. I traced all the lines, all hand...Show More
Old-BiscuitExplorer IIINov 14, 2016Same low pressure if using pump?Did you check/clean 'screen/washer' in city water hose connection?Could be check valve in city water' inlet assembly failing....restricting flow.And IF you have same low pressure using pump........do you have a WHOLE House filter.........clogged up? Is low pressure/flow at all faucets/shower/toilets?Dirty aerators at faucets...plugged water valve for toilet?Process of elimination......one item at a time
Related ContentWater Pressure RegulatorLow Water PressureWater pressure regulatorWater PressureWater Pump
