I have a 2016, 24ft Open Range Lite. The water pressure is the barely a steady stream. At home I hooked up without regulator and made no difference from using a 45psi. I traced all the lines, all hand...
Ok, thanks, pressure is same all outlets pump and city water so i'll start between pump and water in connections and see what's up. Just purchased in Sept. only been out twice so a clog seemed unlikely but.....
