seaweed2ExplorerNov 14, 2016water pressureI have a 2016, 24ft Open Range Lite. The water pressure is the barely a steady stream. At home I hooked up without regulator and made no difference from using a 45psi. I traced all the lines, all hand...Show More
All_I_could_affExplorerNov 15, 2016Open one of your low point drains (used for winterizing) and turn on city water hose. See if you get full flow there.
Related ContentWater Pressure RegulatorLow Water PressureWater pressure regulatorWater PressureWater Pump
