seaweed2
Nov 14, 2016Explorer
water pressure
I have a 2016, 24ft Open Range Lite. The water pressure is the barely a steady stream. At home I hooked up without regulator and made no difference from using a 45psi. I traced all the lines, all hand...
Ava wrote:
From all the problems I read about with new rvs, there could easily be a pinched line somewhere in the construction of the unit. Something to consider if nothing else works.
