sgrizzle wrote:
Yes, this was part of the problem and when I loosened the pump and repositioned it...I was able to decrease the vibrations...it is better, but I still have "bumping" noises and it seems it is due to air from the city water line...
Have you considered using an
accumulator tank, also by Shurflo? I have both a Shurflo pump and tank with no other noise-mitigating components (flexible lines between pump and PEX, cushioning under pump, etc.) and I don't have the noises you describe. There is some noise but not enough to make me pursue this further. Had the tank in my previous RV also and that too was acceptable afterwards.
