dfm
May 19, 2013Explorer
Water pump burps every 35 to 40 seconds for 2 to 3 seconds
6 weeks ago ,when I had the city water connected ,my fresh water tank filled . When I turned on the water pump,water came out of the gravity fill spout. So assuming the check valve at the city water connection had failed I replaced it. Didn't use the trailer since then and now when I filled the water tank,turn the pump on to pressurize the system every fawcett works fine but every 30-40 seconds the pump burps for 2-3 seconds. I have checked every connection I can find inside the trailer and all are dry.I have not taken down the plastic liner on the bottom of the trailer to look for exterior line leaks yet.
Previously when hooked to city water and with the tank filled I could turn on the pump in order to increase waTer pressure if needed,although I seldom did. NOW the water pump will not come on when connected to city water if I turn the pump on and open a fawcett/shower.
I installed the present flojet "4406-143"water pump 7 months ago.Pump is still on warranty . I am thinking that because the water pump burps so frequently and for such a short time that I have a faulty check valve in the pump. When I disconnect the outflow side of the pump and cap it with a plug the pump burps even more frequently and for a shorter time.
Anyone have any comments/help?? What to try next? I took the pump to the dealer and when they capped the outflow it did not burp.I am going to cap the outflow again today to see if it burps when installed in my trailer.
UPDATE....
JUST capped the outflow again while the pump was in the trailer and it burps continuosly for 1second every second! Does this mean the check valve in the pump is faulty and the pump needs to be replaced?/
UPDATE....
