I had are 2014 200qb Kodiak out this weekend and I had to use the water pump because there were no hook ups.I've used it before with no issues but this time all it wanted to do was spit and sputter wa...
Check to see if line that antifreeze is put in for winterization is open. It is on the inlet side of pump and would be drawing air if open or maybe it got moved slightly and is partially open. Also check that inlet hose from tank is attached tightly so no air is drawn in. Randu
