Gonefshin
Oct 13, 2014Explorer
You should have cut offs on the pressure side of the pump. Cut the valve off on the pressure side and see if the pump builds up pressure and cuts off. If it does, you will have to work your way forward from there.
You can also adjust the tightness of the screws holding the pump sometimes to get it quieter.
