WayneAt63044
Dec 08, 2020Explorer II
Was your fresh water tank empty when you added 7 gal of antifreeze? If not, you've already diluted the antifreeze. Do you get anything from the faucets with the pump running? Did you before the antifreeze?
I suspect you would be better off researching "winterizing an RV" to learn the processes if you've not already done that.
