aftermath
Dec 09, 2020Explorer III
PattiWong, Welcome to the forum. Yeah, you will get lots of information here but, sometimes people can be aggressively critical. First off, what you did was not wrong, many people winterize this way. There are better methods but don't feel like you messed up.
My first concern came up when you said that the pump was not circulating the pink stuff from your water tank. Was your pump working before? The bypass winterizing connection is the best if you can easily access your pump. If the pump isn't working, that will be another issue.
Getting the pink stuff into your tank and then through your pipes isn't a big deal. You can flush all of this out in the spring. I would caution you though to take great precautions to avoid getting this into your hot water tank. I did this my mistake and had to deal with foaming water from my hot faucets for most of a season. I think it had something to do with the surface inside my tank, or the heating of any residual left behind. None of this is DANGEROUS, RV antifreeze is not poisonous but it does have a strange taste....
I don't put antifreeze in my FW tank, mainly because it would cost a lot for many gallons. In my trailer access to the water pump is close to impossible so I can't use the by pass system. I winterize my trailer each year with compressed air. That is a discussion for a later time. Best wishes as you move forward learning the ropes.
