Monaramblee
Dec 09, 2020Explorer
Wow you guys have jumped to alot of conclusions and assumption. Using fresh tank to winterize as mentioned is completely normal and suggested in some manuals. I did not read that he deluted the pink with water it was only put as a question unless i missed it. Drain the hw tank and bi pass it then figure out which valves need to be open or closed and pump away... no need tor a kit if u have the pink stuff in your fresh tank.
