Grit_dog
Dec 09, 2020Trailblazer
I’d open your tank drain and drain out the af you put in there.
If it’s not diluted you can reuse it.
And presuming it’s not terribly cold, I’d fill the tank some with water and drain, a few times, while you’re doing the other winterization.
May as well get the tank flushed out and clean while it’s fresh. Less to do in the spring!
