Old-Biscuit
May 13, 2016Explorer III
bobm253 wrote:Old-Biscuit wrote:
Bathroom faucet is flowing as much water as pump can supply........therefore pump is running full out w/o being able to reach pressure switch set point to shut off
Kitchen faucet and shower.......
Pump is able to reach shut off set point....momentarily
Shuts off/turns on----quick cycling (pulsating) due to resistors at kitchen faucet and shower (resistors are typically in cold/hot lines/connections on kitchen faucet and in hose at shower---some can be removed/others can be enlarged using a drill bit)
Would I have to take apart the faucet to get to the restrictor? Where are they commonly found?
Kitchen faucet.......resistors would most likely be in the ends of cold/hot lines. Disconnect at supply fittings----look in ends that are part of faucet assembly
