jmartin99 wrote:
Okay, I got the pump installed and filled the tank up a little over half full. I am not exactly sure how to hook up the wires. I have a white wire and a blue wire coming out of the wall. The pump has a red wire and a black wire. I have tried it both ways and it does not appear to be priming itself. I am assuming it would try to push water back into the tank if the wires are not hooked up the way they are supposed to be.
I then took the hose coming from the tank off and sucked until I got water and then put it back on the pump and it still would not pump. Any ideas on how to get it to prime itself?
Thanks!
Jeff
Humm,,,, I don't have a lot of info here as to why your pump was not mounted. Is this a new TT? or, a used one your bought? If a used TT I wonder if the reason it wasn't mounted is because it doesn't work?
