Deano_1ExplorerOct 18, 2021Water pump question Where would I add a winterization kit or use an existing fitting to add antifreeze to my system? Is the white plastic circle to the left of the pump a filter? ThanksShow More
enblethenNomadOct 18, 2021It is more of a screen then a filter. You can clean debris such as sand by removing the top clear portion.
Related ContentWater pump?Water PumpWhy no hot water?Water pumpWater Pump Failure Traveling To The Eclipse
