Deano_1ExplorerOct 18, 2021Water pump question Where would I add a winterization kit or use an existing fitting to add antifreeze to my system? Is the white plastic circle to the left of the pump a filter? ThanksShow More
FishermanExplorerOct 18, 2021I would believe that filter is on the inlet side of the system, no sense trying to run debris through the pump. That's how both mine have worked.
Related ContentWater pump?Water PumpWhy no hot water?Water pumpWater Pump Failure Traveling To The Eclipse
