jules6
Jul 24, 2017Explorer
Here is my two cents
There are two check valves in your water system,
One is on the discharge of your water pump and the other is on the city water input to your RV.
If either one is leaking you will lose water pressure which will cause your pump to run
It only takes a few drops of water loss to make the pump run.
44,066 PostsLatest Activity: Oct 04, 2013
