RamblinAnne
Jul 24, 2017Explorer
tattoobob wrote:
SHURflo Accumulator Tank
some people install these, Not sure how old you pump is but you probably want to change it, could be your pressure switch a check valve problem or a leak someplace
I'm guessing it's as old as the camper - 13 years. It could probably use replacing. But it still seems to put out good pressure. If I am sure there is no leaking going on, is the intermittent running going to cause any damage? Can I simply replace the pump down the road or is this something I should immediately address? Also, how do I check a check valve problem?
44,066 PostsLatest Activity: Oct 04, 2013
