towpro
Feb 08, 2017Explorer
Artum Snowbird wrote:
I thought I was upgrading mine to a quieter model. I should have just wrapped it up in foam rubber to dampen the noise as I ended up doing with the new one.
So... the question is why?
I have not looked too far into new camper yet (bought it, used it 1 week, and put a cover on it) but on my 5er the pump was installed with PEX (plastic) pipe. replacing the inlet and outlet pipe with rubber lines isolate some of the noise that transmittes through the pipe.
I found rubber lines with correct fittings (or adapters) at a big box home store to do the job. or you can look up Shurflow pump silencer kit for $25.00 and save the time of making your own.
